No sign of the ECU directly under the radio where both the manuals I have say it should be so where is it?
I found easy access from the passenger footwell. well thats where i wired in a piggy back ECU into from.
my ride, check it here: https://www.aussiemagna.com/forums/sh...ight=lowridersOriginally Posted by Richard Hammond
AMC///two tone division
AMC///Black and 20 inches divison
AMC///magna awards finalist 2009
Thanks for your quick replies Mal and Lowrider. I assume the heat box is the large plastic structure behind the radio. Still can't see anything. I'll try and get a photo of what I see when it's not raining. Is it under a plastic cover or anything like that? I'm looking for a silver module.
Does the position differ on different models?
What did you remove to get access from the passenger footwell lowrider?
The position is the same on all 3rd gens.
Pull back the passenger side carpet from the frontmost inner section of the footwell where one's right foot would go, which will reveal a metal plate located on the lower RHS of the footwell, on the side of the tunnel, under the console trim. Unscrew it, behind it you will find the ECU staring at you, possibly sheathed in a plastic sheet.
Thanks very much for that advice ammerty. I'll try that procedure in the morning. Looking forward to finding this thing.
Did Riverman ever find his ECU??
